uplift uz+ vertical downward load case not converging
c.lucchetti
c.lucchetti
Already read and modificate as suggested in https://forums.autodesk.com/t5/robot-structural-analysis-forum/self-weight-load-case-not-converging-...
 I have the same problem. I have only z- load cases and calculation do not converge.
What's wrong with my model? Someone can help me?
Thank you in advance
Simau
Hi @c.lucchetti
Please correct non linear analysis as below
Model attached
M. Agayr
c.lucchetti
Thank you very much. I would like to understand what was the problem to avoid other problems.
In non linear analysis should load cases be always auxiliary cases?
And what about combination? I suppose they are not auxiliary..
Now in previous file (attached) I added uplift wind loads and seismic Ex loads and than I try with combination.
Same previous problem. Is it a load value problem or an other  issue?
Thank you again..
Simau
Hi  @c.lucchetti
Yes, except self weight
Correct, if sw is included
the non-convergence is due to the fact that the structure is not stable.
For example, If we increase the pavement load to 20kN/m², the model converges
Model attached
M. Agayr
