Uniform Planar Load on a panel
Babak.moussavian
Babak.moussavian
Hi.
In the attached model I am trying to assign a a uniform planar load to one side of a panel .
If I use -5 kPa as local Z and run the analysis then the load will be applied in the global Z axis.
Is this a bug in RSA 2024 or I am doing something wrong?
Model is zipped and attached.
B.M.
Romanich
Hi @Babak.moussavian,
I have deleted the load in your model and applied it again, it seems no issues:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Babak.moussavian
Hi @Romanich!
Thanks for your reply!
The load seems to be applied correct when you use "Uniform Planar Load" as the load is applied on the entire panel, however the problem arise when "Uniform Planar Load on Countour" is applied only on selected parts of the panel.
The load will be applied in the global Z direction and not in local axis of the panel!
B.M.
Romanich
I think this is a representation only bug:
From help:
To ensure that the planar load assigned to elements displays correctly, you should generate a model or perform calculations, and additionally, select Loads > Forces generated automatically in the Display dialog.
Roman Zhelezniak
