Unexpected Non-linear model definition
1234eddie
1234eddie
Hi all,
I found a for me weird behaviour with non-linear model definition. it looks like that some values of D1 does not work properly?
see picture below
These are the graphs i expect to see at every defined model.
the weird behaviour is if i change the value than i get the graph expected.
File is attached.
@Artur.Kosakowski @okapawal
Hope someone can explain why this happens?
data is written with dynamo script.
thanks in advance
Gr Edward
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @1234eddie
Probably model was created using version older than 2022 (for which problem with non linear supports/releases) diagrams was corrected. When you modify support using in 2022 diagram is recalculated correctly.
Refer  to Incorrect presentation of non-linear support properties diagram in Robot Structural Analysis
Krzysztof Wasik
1234eddie
@Krzysztof_Wasik
thanks for your reply, but that's not the case. file is created with RSA2022
File created (version): 35.0.1.8274
File modified (version): 35.0.1.8274
but you are saying that's only representation that's wrong or is the non-linear model also wrong when this happens?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @1234eddie
You are right it is problem will diagram scaling.
  1. Click right mouse button on diagram
  2. Select Diagram Parameters
  3. Switch off Automatic range
  4. Define range for x axis (-30;30)
  5. OK
  6. Review diagrams for supports
Refer to video
As far as I could check despite incorrect diagram presentation support definition is recognized correctly
Krzysztof Wasik
1234eddie
@Krzysztof_Wasik
Thanks for the video and your check. I did not know that you could change the diagram view.
Gr Edward
