Unable to change plan view to other perspectives/View of vertical section plane from structural axis
Hello
Here is a problem I run into when I go the plane view, click the UCS and try to change from XY plane to YZ or XZ and not being able to do so. I want to show cutting views from different structural axis without having things behind. The highlighted buttons are the ones does not work.
Stephane.kapetanovic
Click on view
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
But it is not possible to show clean axis section view in that mode. Is it possible to do so and hide things in the front or behind the cutting plane?
I found the solution. Change to 2d in View tab
