Truss Forces
Truss Forces
Message 1 of 10
Truss Forces
Hi there,
I am currently doing a truss design for a 40m truss with point loads of 71.08KN at 0.5m across the whole length, however when i have ran the calculations the max force within the internal members is approx 10MN for compression and tension,
Could someone please help me as I am unsure whether these internal forces are correct and if they are could someone suggest a way in order to reduce them
Many Thanks
2032165b
Replies (9)
Message 2 of 10
Simau
Hi @Anonymous
Just increase the height of the truss.
M. Agayr
Message 3 of 10
Rafacascudo
You should reconsider your truss geometry . All your sections chord or diagonals are the same. This is how it will look if really is built
What´s the point of choosing a truss like this?
Easier would be building a single girder!!!
Try starting with 45 degrees diagonals
Rafael Medeiros
Message 4 of 10
Thanks Rafa
I chose that geometry because the point loads are at 0.5m spacing so I chose those diagonals to go between points loads
Is it possible to make the diagonals greater even thought there will be no members going between the nodes of the point loads?
Message 5 of 10
Rafacascudo
Hard to say without knowing what kind of structure is this and from where do these 71Kn loads come. Maybe the the best engineering solution will be a regular girder as I suggested before.
Rafael Medeiros
Message 6 of 10
The 71KN are from the reactions of beams, is it possible to therefore add a UDl onto the truss as a bar load?
Many Thanks
2032165
Message 7 of 10
Rafacascudo
Sorry , what is UDl ??
Rafael Medeiros
Message 8 of 10
Sorry a uniformly distributed load across the top of the truss,
Is there a way I can add this instead of having the point laods
Message 9 of 10
Rafacascudo
Of course . You just have to change the structure type from "truss" to "2d frame" so you can apply this type of load along the bar lenght, and then consider other forces different from only axial tension and compression.
Rafael Medeiros
Message 10 of 10
Thanks for your help Rafa
