tool bars is too small
Capture2.PNGhello everyone ! I hope you help me  to make this tool bars as a normal (larger than exist )
Replies (17)
Refaat
Hi
Try to do this attempt.
Refaat
Refaat
Hi
Did you try to change the screen resolution?
Refaat
hi
yess I changed but did not work
default screen resolution 3840x2160 I changed to 1980x1080 still does not
larger
hi
yes 😞
saclovitzky
Can you not reinstall the software again?
I reinstalled but still like that didnot change
saclovitzky
Can you try to go to Control Panel/Appearance and personalization and try to play with "Display", "Resolution" and see if there's any change.
not change ! 😞
AhmedZA
I think this problems related to systems DPI scaling settings
Maybe This One Can Help You
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/dpi-scaling-autocad/m-p/5162511
saclovitzky
Try to reinstal it to a different computer, and see how it goes.
I suspect it is more of a hardware problem not the software.
hello thank you I have problem with step 2 I don't know how to write code
yes you are right I installed on my friend's laptop I worked normally
saclovitzky
If that's the case, reformat your computer laptop and reinstall windows OS
Hi
I formated my computer twice did not change !
AhmedZA
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0" xmlns:asmv3="urn:schemas-microsoft-com:asm.v3">
<dependency>
  <dependentAssembly>
    <assemblyIdentity
      type="win32"
      name="Microsoft.Windows.Common-Controls"
      version="6.0.0.0" processorArchitecture="*"
      publicKeyToken="6595b64144ccf1df"
      language="*">
    </assemblyIdentity>
  </dependentAssembly>
</dependency>
<dependency>
  <dependentAssembly>
    <assemblyIdentity
      type="win32"
      name="Microsoft.VC90.CRT"
      version="9.0.21022.8"
      processorArchitecture="amd64"
      publicKeyToken="1fc8b3b9a1e18e3b">
    </assemblyIdentity>
</dependency>
<trustInfo xmlns="urn:schemas-microsoft-com:asm.v3">
  <security>
    <requestedPrivileges>
      <requestedExecutionLevel
        level="asInvoker"
        uiAccess="false"/>
    </requestedPrivileges>
  </security>
</trustInfo>
<asmv3:application>
  <asmv3:windowsSettings xmlns="http://schemas.microsoft.com/SMI/2005/WindowsSettings">
    <ms_windowsSettings:dpiAware xmlns:ms_windowsSettings="http://schemas.microsoft.com/SMI/2005/WindowsSettings">false</ms_windowsSettings:dpiAware>
  </asmv3:windowsSettings>
</asmv3:application>
</assembly>
Hi
Your  problems still not solved yet Smiley Sad
For me I haven't faced such problems before Smiley Mad
Have you tried to open attached manifest file  in notepad. and then Save it as ".exe." file ?
try also to rename  photoshop.exe.manifest as  shown in attached link "robot.exe.manifest"
saclovitzky
Did you update all the latest "drivers" for your OS? Just have a quick look at your friend's laptop/computer configuration.
It is really so strange that it works in your friend's laptop at it doesnt work for you. What is your firend's OS ,is that the same with your OS?
What I am trying to suggest is to really investigate what's the difference of your computer set-up compared to your friend.
