Thin walled Section definition
Dear Robot support,
I have done a cross section as a thin walled section. I have the following few questions:
- The model is rather big (about 240 nodes) although I would not think it is extraordinary big. Neverthelss it takes 3 minutes to calculate. This is not quite handy as everytime I close the result window all the process as to take place once again (even if do not make any change and I want only to generate the calculation note). I was wondering whether the model is correct. I will have to investigate various section and make iterative changes hence it may get a little too time consuming..
- By mistake I accidentally draw two perfectly overlapping lines (by copying twice back and forth). That was noticed so it has not been a problem. Is there any check tool or any procdeure to make sure that overlapping lines are not considered?
- Is there any way to split one drawn line in two (equivalent of edge division for a contour)? That would be quite handy as I have to divide the structure in correspondance of the centroid which obviouly I know about only after result generation.
Model enclosed.
Thank you.
