HI @maksimd9PUZW
Due to practical considerations and the limited availability of technical documentation on the subject, it is currently not possible to explicitly account for monosymmetry, or any other asymmetry, in the design against lateral-torsional buckling. However, it remains essential to safeguard against both direct and indirect torsional effects, whether through calculation, bracing, steel decking, or similar means.
The use of the buckling resistance of a bisymmetric section is standard practice, which is why informational messages are displayed.
For any non-standard scenarios, users can manually enter the critical moment in the dedicated input field.
Regarding alternative calculation approaches, if you have access to the CTICM journals, you may find particular interest in issue No. 2-2016, Elastic Instability of Flexed U-Section Bars, and issue No. 4-2013, Formula for Torsional Stresses in an Open-Section Beam.
These articles not only examine the influence of loads on beams but also take a step further by reassessing the applicability of existing formulas for specific section types.
They highlight the importance of considering instability effects both in global structural analysis and in local verifications.
These topics present valuable opportunities for development teams to monitor and potentially incorporate the recommendations into future updates.
You can also visit the CTICM applications page to see if there's anything [LTBeamN, TORSION] that could be useful for your work.
To work with databases and gain a full understanding of how to create them from start to finish, you can find several informative posts on this forum by using the search function.
The main method involves copying an existing database and then modifying, deleting, or adding section types as needed—while preserving the existing structure.
An alternative approach, for those with programming knowledge and an interest in XML, is to generate the database and perform section calculations in a single step.
I have developed a program that enables you to read, explore, and work with databases, and more.
Although it hasn’t been widely downloaded yet, I encourage you to give it a try. (SectionXmlDatabaseCatalog, forum page)
Please also note that if you want to quickly model a bar with thin-walled section using finite elements for deformation and stress calculations, you can use the ExtrudeLines tool, available on the Autodesk App Store and on its dedicated forum page.
For the classification of thin sections, here is a document. (EC3_thin_walled_sections.pdf)
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
