technical requirements
julien----
Observer Observer
julien----
Observer
Observer
I have to buy a PC to run Robot. I need to know the technical specifications. I saw the web page ( https://knowledge.autodesk.com/fr/support/robot-structural-analysis-products/troubleshooting/caas/sf... ) but the information about the processor and the graphics card are not detailed.
Does Robot use the processor or the graphics card for calculations ?
Which configuration do you advise me to handle medium and large size projects?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @julien----
For RSA it is better to focus on the speed of the processor rather than numbers of cores as most operations are sequential. The standard graphic card should be just fine.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
