Table with the maximum Forces in Bars
luismrf
luismrf
I ´m working on a steel structure, made by angle bars, i´ve done much combinations of actions.
I would like to know if it is possible to obtain a table with only the maximum forces that the bars are sujected to, so i can preform a verification manually, is it possible?
rsousa_
You have several ways of doing this.
1. If you go to table--> forces and then select at the bottom envelope or global envelope. You can always change some settings at right butom of mouse --> table columns.
2. you can also do this with API with some excel sheets provided in this forum  (https://forums.autodesk.com/t5/robot-structural-analysis-forum/useful-addins-for-robot-api/td-p/3899...  under different bars forces tables)
Regards
