Does anyone know if it is possible to extract a table from Robot which provides the displacement of each node for each mode shape when undertaking a modal analysis?
STL
Solved by Artur.Kosakowski. Go to Solution.
With all respect I think you may have misunderstood the type of results available from a modal analysis.
Modal analysis results in "normalised" deflections/displacements, and as such the number reported is not an "actual" deflection. If you ran a spectral analysis (for example) then you could take the deflections / displacements at face value.
Tony
As Tony wrote these are not real displacements but the 'numbers' are available in the dynamic analysis result table (use RMB to mark the appropriate columns).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Tony Artur,
Many thanks for your replies. Tony, you are right I was misunderstanding the results. Artur, I think your attachment is what I was looking for.
Many thnaks
STL
