Good evening! Roman thanks.
Changed in the settings excel separator character integer and fractional parts and robot began to read the new spectra.
About the behavior of the decryption values x and y axes, it is now clear that the robot is reading these figures puts appropriate checkboxes. But honestly I did not understand a pattern between these codes and how fields are filled in the Robot. Teach, please read the codes.
I spectra in all three directions loaded into a single book excel and created a spectrum that contains data of all three.
Based on these data, the robot did spectral estimation.
According to the basic forms it is clear that it feels like a real situation. Yet there are new questions.
1. After determining a spectrum robot automatically creates based on her new 3 loading in X, Y, Z. Total for my three initial spectra obtained 9 loaded excluding combinations.
Tell me, please, and not better to ask for each direction (X, Y, Z) its original range, and that removing the intermediate generated by robots? Or am I wrong?
2. I looked at the results of calculations for spectral analysis, in particular, looked magnitude strains. They were very small than I expected. The earthquake of 1988 in the midst of the power possessed with a magnitude of 7.0. Ghoukassian seismic data, which we use in this example was from the epicenter at a distance of 38 km. I'm still inclined to think that it could not reduce the effect on many of the earthquake.
Please tell me what could be the reason, so no real results of the calculation?
Добрый вечер! Роман спасибо.
Поменял в настройках excel знак разделителя целых и дробных частей и Робот стал читать новые спектры.
По поводу расшифровки значений поведения осей Х и У, теперь понятно что Робот читая эти цифры ставит соответствующие чекбоксы. Но если честно я не понял закономерность между этими кодами и как
заполняются поля в окне Робота. Научите, пожалуйста, читать эти коды.
Я спектры по всем трем направлениям загрузил в единую книгу excel и создал один спектр, который содержит в себе данные из всех трех. На основе этих данных в роботе сделал Спектральный расчет.
По основным формам видно, что вроде все похоже на реальную ситуацию. Но все же возникли новые вопросы.
- После определения одного спектра Робот автоматически создает на основе нее 3 новых нагружение по X,Y,Z . Итого для моих трех исходных спектров получается 9 нагруженный без учёта сочетаний.
Скажите, пожалуйста, а не лучше зразу задать для каждого направления (X,Y,Z) свой исходный спектр, и удалить промежуточные которые сгенерировал Робот? Или же я ошибаюсь?
- Я посмотрел результаты расчетов по Спектральному расчету, в частности посмотрел величины деформаций . Они оказались очень маленькими чем я предполагал. Землетрясение 1988-го года в эпицентре обладала мощность с магнитудой 7.0. Сейсмостанция Гукасян данные, которого мы используем в этом примере находилось от эпицентра на расстоянии 38 км. Я все таки склонен думать, что это не могло на столько уменьшить эффект этого землетрясение.
Скажите, пожалуйста, в чем может быть причина, столь не реальных результатов расчета?
