Switch order in tables
tomas.jonebratt
tomas.jonebratt
I have 2 questions.
Is there a way to make the cases into order after case number? Or a way to manually move for example case 2 below to between case 1 and 3X? I know that i can go to manual combinations, remove all cases and the put them back in the right order, but is there a more convenient way?
Since i added DL2 later than the rest it is now at the bottom of the load table, can i somehow put it in numerical order or manually move it?
Romanich
Hi @tomas.jonebratt
Yes, you can :
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
tomas.jonebratt
I like to edit the numbers using the "Table edition" tab in "Loads". So what i meant was is it possible to do it in that tab?
And the same for load combinations, i like to edit them in the edit tab and would like to have the load cases in "correct" order as i explained above, is there a way to do this?
Romanich
Not possible, only on the "Cases" tab.
Double-click on the header Case:
Roman Zhelezniak
