Message 1 of 8
Sway steel structure
Hello all,
I was reading other topics and testing some procedures on steel portal frames and i'm not sure if the following procedure is correct for a sway portal:
1) make a buckling analysis proofing thas i'm in presence of a sway structure (as seen on other topics by calculating alfacr for global buckling mode)
2) change linear combinations to "P-Delta" (not large displacements)
3) set member definitions as non-sway and define proper buckling lenghts
4) run steel design
Is this correct?
Do i've to break columns and beams in order to have several intermediate points?
Thanks in advance,
Happy new year,
RR
