structure total weight
EnricoCorvaglia
EnricoCorvaglia
Hi evreyone
I have the attached model, and i want know the total weight of the structure. Someone can help me?
thanks
(i usually find this information in calculation notes in Analysis menu, but in this case there is no information about weight)
rsousa_
well, you can check reactions table, and then check the sum for self weight load case.
I have an old version of RSA, so you need to check in your version, but apparently your structure weights 5.77KN.
I always recommed to check the sum of reactions with manual calculations.
Regards
EnricoCorvaglia
is it possible that a software like this isn't able to show the total structure weight in the calculation report??????
i don't want belive this... it is unthinkable....
Pawel.Pulak
Autodesk Support
Autodesk Support
Your model is with phases. After removing phases weight and other related properties are reported in the calculation note.
If this post answers your question please click the "ACCEPT AS SOLUTION" button (the button visible when logged to the forum). It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
