Structural detailing
Message 2 of 11
hi guys, i have done designed my structure but i m wonder how can i withdraw all the beams reinforccement detailing of the whole structure in one click instead of clicking at every beam and check the reinforcement. If we click beam by beam is very troublesome and slow. Thank you so much
Replies (10)
Message 1 of 11
Message 3 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you mean to display reinforcement distribution in the 3D model of a structure then this is currently not possible.
Artur Kosakowski
Message 4 of 11
Spoiler
hi thx for your reply. Actually what i want is like withdraw all the beam details in one autocad file juz like the file i attached below. it wil be easier cause i do not have to click every beam one by one
Message 5 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
There are two options I can think of:
1. In Robot you can generate drawings of each beam and then arrange them on a larger page. Then you can just access such created 'bigger' drawing and see all of them at the same time.
2. Export drawings to ASD Reinforcement and arrange them as you want to.
Artur Kosakowski
Message 6 of 11
hi 😃 thank you for ur reply.. yea u got my point. is there any option that all beams can be withdraw instantly instead of one by one? cause the drawing that i attached before was generated by the other software in juz few clicks, it eventually saves a lot of time.
Message 7 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
When you run calculations of reinforcement mark generation of drawings.
Save rtd file and open the drawings in ASD marking the check box next to the Robot file name.
http://forums.autodesk.com/t5/Robot-Structural-Analysis/export-drawings-from-robot-2012-to-asd-2013/...
Artur Kosakowski
Message 8 of 11
hi sir, thank you so much! btw, is it possible to export file from robot to autocad, cause ASD for student has been taken away and i dun get to use it anymore..
Message 9 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Generate drawings in Robot then from Drawings layout:
Rafal Gaweda
Message 10 of 11
hi sir, thank you so much.. btw when i wana design slab right.. i have done the following steps but ntg comes out for my slab reinforcement. can u show me the proper way to design for a slab.?
this is what i have done:
1) highlight all the floors
2) slab requried reinforcement
3) then click calculate at the "plate and shell calculation"
after finished calculating, i choose slab provided reinforcement.. then i see ntg =.= may i know is this the proper way?
Message 11 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
example movie : http://screencast.com/t/zuxKpIEN91K9
Rafal Gaweda
