Message 1 of 12
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I modeled a steel structure with a strip foundation. I would like your opinion for my way of modeling. I used beams, columns, panels and rigid beams. Please find the attached file.
-Do you think that it works ok?
- even though i used the "correct" tab, when I run the model and the program creates FE again it gives me nodes really close to each other ( see the bottom nodes of rigid beams that I use to connect the foundation beams with the foundation panel). How I can correct this?
thank you in advance,
Sofia
