Stress analysis missing
henlinBM2LR
Message 1 of 10
henlinBM2LR
I can't find stress analysis for either bars or structures, does anyone know why and how I can see them?
Replies (9)
Message 2 of 10
Stephane.kapetanovic
Hi @henlinBM2LR
Bars StressesStresses/NTMMaps (panels), StressesGlobal Analysis - Members
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 10
henlinBM2LR
I found this video from Autodesk. Has this been phased out and replaced with what you linked
https://help.autodesk.com/view/RSAPRO/2022/ENU/?guid=Robot_GSG_Tutorials_Tut_Frame_3D_Design_3D_Anal...
Message 4 of 10
hi @henlinBM2LR
2025 version : https://help.autodesk.com/view/RSAPRO/2025/ENU/?guid=Robot_GSG_Tutorials_Tut_Frame_3D_Design_3D_Anal...
Best Regards
Message 5 of 10
henlinBM2LR
Thank you for the updated link, but the issue lies in that I do not have 'stress analysis' in the dropdown menu, as described in point 2 in the link you provided. Please see the first attached image.
Message 6 of 10
no problem here, have you updated your results and selected at least one bar?
Message 7 of 10
Rafacascudo
It also happened here and it also was absent on the Results menu. But ,at least in the menu ,you can make it available on Tools/customize menu/Results and then Stress analysis may be in red . Just click it to turn it into green. Click also in the sub menus below stress analysis.
Then it will be available on Results menu
Rafael Medeiros
Message 8 of 10
jsk236YARVK
Observer
Observer
Hi, I am having the exact same issue with my model and was wondering whether this has been solved and what you did? Thanks
Message 9 of 10
jsk236YARVK
Observer
Observer
I did this for my model as I have the exact same problem but it still cant seem to show up, do you have any ideas as to what else could be done?
Message 10 of 10
okapawal
@jsk236YARVK   Probably you use Building Design structure template, where the Stress Analysis is hidden by default.
Change structure template by Geometry > Structure Type...    and click Shell or 3D Frame as applies to your model.
Waldemar Okapa
Sr Product Owner
