stirrups
stirrups
MUHANNAD.ABU_ABDO
Message 1 of 11
stirrups
MUHANNAD.ABU_ABDO
Muhannad M.Abu Abdo
Structural Design Engineer
Replies (10)
Message 2 of 11
HoshangMustafa
Hi
This means that the position where the first stirrup will be set. This data is input by you. So you can change it to other value (e,g, 5cm instead of 2m).
Message 3 of 11
MUHANNAD.ABU_ABDO
Ok , what about decrease the distance between stirrups in the first 2 meters ? how i can do it ? for seismic requirements you need to intensification the stirrups
Muhannad M.Abu Abdo
Message 4 of 11
HoshangMustafa
Hi
You can use stirrup distribution. Please find the attached file.
Message 5 of 11
MUHANNAD.ABU_ABDO
yes i tried, but the software put two stirrups over each other
Muhannad M.Abu Abdo
Message 6 of 11
MUHANNAD.ABU_ABDO
i want to edit distribution of stirrups , but the robot put a new stirrups with new hangers !! why ? how i can edit the original distribution ?
with all respect
Muhannad M.Abu Abdo
Message 7 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 8 of 11
MUHANNAD.ABU_ABDO
thanks a lot , but my questions is the number of stirrups is 22 and this distribute from on side left or right !! this will give you intensification for stirrups from one side ! so what about other side , in reality there's symmetry in the distribution ??
Muhannad M.Abu Abdo
Message 9 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 10 of 11
MUHANNAD.ABU_ABDO
Many thanks ... it's work ... could i ask small question ? i want to change angle of hook reinforcement but there's problem some bars done but others not ?
what is the correct way to do it ? and i want to ask is there's main bars shapes ? or it's just one ?
Muhannad M.Abu Abdo
Message 11 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you mean the one with no hooks on the left hand side then I think it is the anchorage loop rather than the top reinforcement.
Artur Kosakowski
