Steel Design Different utilization ratio in different places of the same product
ROBOT.JPGtwo locations showing utilization of the same section having different results.
@Anonymous Artur Kosakowski edited the topic for better findability
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Peter,
Please check this article:
ROBOT - Steel Design module and Code check tab of bar properties dialog show different values of rat...
Artur Kosakowski
Thanks for your info however I believe there must be a different issue and it's not due to simplified calculation.
For this member my simplified hand calculations gave mi utilization of 0.96.
1.27 as per your estimation is far away. In my opinion there is another bug.
R.
Peter
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Peter,
The estimated value may not be accurate (as per design of this functionality) and it is hard to compare what simplifications were used by you and the program to display the ratio in the bar properties dialog. The bottom line is that you should always run the final verification in the Steel Design module.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
In case you need a quick check on the final design ratio you can display it as a map on bars
Artur Kosakowski
