Steel design connection
Message 1 of 13
Can someone tell me why i cant apply beam-column web connection to bar 1 and bar 331?
Replies (12)
Message 2 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Such connection type is not available in Robot.
Artur Kosakowski
Message 3 of 13
Mohammed_Ata
Do you mean such one !
Or this one (bolted)
Message 4 of 13
Exactly. However i can't apply that kind of connection for the above mentioned bars.
Message 5 of 13
Mohammed_Ata
OK. no problem.
See this tutorial
May you have defined another connection type for that node so, you should delete the old one and define the new.
Message 6 of 13
But it's not applied to the structure?
Message 7 of 13
Mohammed_Ata
Message 8 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Mohammed,
Thank you for trying to help but my understanding is that the beam is actually rotated by 90 degrees so that its web is perpendicular to the column. In Robot such geometry of the connection is limited to beam to beam web connection with loads acting in the direction parallel to the secondary beam web.
Artur Kosakowski
Message 9 of 13
yesterday55555
@Artur.Kosakowski  Can you please tell me the way that I can design this steel connection type in Robot structural ?
Kết quả hình ảnh cho liên kết dầm cột thép
Message 10 of 13
Simau
Hi @yesterday55555
try to split the column (near the peak) and then create your connexion
M. Agayr
Message 11 of 13
yesterday55555
But is that right way to design ?
Message 12 of 13
Simau
No, just a tip
Your kind of  connexion not available.
M. Agayr
Message 13 of 13
yesterday55555
I know that this type connection is not availble, but I still try to find that way that I can use RSAP to design without excel sheet
