Steel Connection Design Issue
andrew_cross1
andrew_cross1
When trying to use the connection design module on a steel truss I have created I get the below error when I try to create a new connection design:
'Number of detected common nodes: 1
Number of created connections: 0
Remarks:
- program is unable to define connections for the current code: 1'
Can you please clarify the cause and how I can resolve the issue.
Please note some of the sections used were non standard sections and were created within 'New Section - Parametric'
Andrew
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @andrew_cross1
Probably section type is not supported for this connection. Please share your model for verification.
Krzysztof Wasik
andrew_cross1
Thanks @Krzysztof_Wasik please see attached
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @andrew_cross1
In Robot truss connection diagonals can be defined using rectangular or circular tubes.
Diagonals are not recognized when defined as I sections.
Please refer to Available sections for connection definition in Robot Structural Analysis
Krzysztof Wasik
andrew_cross1
@Krzysztof_Wasik thank you for the clarification
