I am trying to appraise an existing steel column to BS 5950.I have modelled the column in three parts as first screenshot, and set the supermember 1001 comprising bars 100,200 and 300.
The first lift height is 7.837m, with effective length for compression buckling and lateral torsional buckling as 0.85*7.837 =6.662m ( Weak axis)
The second lift height is 6.010m, with effective length for compression buckling and lateral torsional buckling as 0.85*6.010 = 5.109m( Weak axis)
The strong axis is unrestrained over the height and effective length is 1.0*13.847=13.847m
I have set the ‘K9 Column’ design parameters based on these design assumptions:-
Please note that I cannot override the sway to non sway?
However the design calculations do not appear to use the 0.85*Length for the weak axis slenderness or LT buckling. Please refer to following picture.
Can you give any tips why the steel design module does not appear to utilise this?
Another query is, does RSA only report the most onerous 'lift' of a column. In this case, the upper portion?
I have attached model
Cheers
