Steel Beam Vibration - Response Factors
Afternoon,
I need to check the response factors of a slim composite metal deck that is supported by steel beams. The steel beams span onto additional steel beams and into deeper stiff RC down stand beams. The floor slab is to be used for gym loading where I believe the response factor would be quiet high (rather than very low like an operating theatre where vibration would need to be kept to an absolute minimum).
How can I check the response factors in Robot?
Adam Barnes
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Adam,
Please watch the recording of the 12th Robot webinar available from here.
Artur Kosakowski
Artur,
I haven't been able to get to the webinar video from your link. Could you try it again please or provide me with further advice about how I can watch it please.
Any other information on vibration response factors using the software?
Adam
Artur.Kosakowski
Autodesk Support
Autodesk Support
You just needed to select it from the list of all available webinars but here is the direct link to its recording on YouTube:
Vibration of floors and footfall analysis in Autodesk Robot Structural Analysis Professional
Artur Kosakowski
