Steel beam restraint - lateral torsional buckling
skellyRSA2023
skellyRSA2023
If i have a steel beam which is simply supported which supports a concrete slab all along its length, is there a way in which i can specify the beam to be fully restained along its length, so as lateral torsinal buckling does not become an issue in RSA.
S.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @skellyRSA2023
Yes, you can set it in this way:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
