Steel beam deflection not shown in calculation output
Hello
I`ve a problem with a steel beam deflection in a steel stairs structure: I can see the deflection in the results.
Please see the picture below
But I can`t see the deflection in the steel design analysis calculation note (cantielever).
What I have to do?
Thanks a lot.
Regards
Giacomo
Artur.Kosakowski
Autodesk Support
Autodesk Support
The lower part is intended for columns. For cantilevers you should look at the upper part and mark the cantilever option.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
For columns:
Artur Kosakowski
Hi Arthur,
Where can I get this pdf with "How to create a model" from?
Dan
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please watch the recording ofthe 3rd Robot webinar from http://forums.autodesk.com/t5/robot-structural-analysis/robot-structural-analysis-webinars/td-p/5523...
Artur Kosakowski
Thanks a lot for the reply. It works for the deflection but I can`t see the forces. Please see the picture below.
Don`t have you a PDF version?
It will be more helpful.
Thanks a lot
Giacomo
Artur.Kosakowski
Autodesk Support
Autodesk Support
Atatch the file please. Thank you.
https://autodesk.box.com/RSA-ENG-3
Artur Kosakowski
