Is it possible to create a solid object like this one (bottom plane is parallel to XY and upper one is not)?
Thank you for the reply. Looks like this method works, but its time consuming... I am trying to build geological massif according to sections and geo points with appropriate coordinates and heights. If I could just select the contours that define exact layer it would be much easier, but I get this type of message:
Hi @Jummybear
It seems that you have created contours only. Before solid definition define Faces from contours. using Geometry>Panels
I did faces from contours but still with no success. Can you be so kind and record of short video of how you make solid from faces? I get either an error message or some mystic solid (with no properties) which appears in dialog box but not in view window...
PS Your first video is now unavailable at least for me... "login.microsoftonline.com refused to connect."
