Snow/Wind Error Code
Message 1 of 8
I am trying to add a wind/snow load onto my 2d frame,
the error code Snow/wind error code: 0x0006000b is appearing
Anyone know how to solve this so i can apply this wind/snow load
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach your model?
Artur Kosakowski
Message 3 of 8
Please find the attached model
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The climatic load generator is intended for typical warehouse like structures and is not able to generate loads for bridges.
Artur Kosakowski
Message 5 of 8
In that case is there anyway to apply a horizontal live load which would represent the wind/snow load
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
You can always apply nodal or bar loads representing wind load manually however I'd say that it may more adverse effect if acting in the direction perpendicular t the bridge (3D model required).
Artur Kosakowski
Message 7 of 8
Hi @Artur.Kosakowski
Thanks for your help
How do i then add a lateral load representing wind in the perpendicular direction to the bridge
thanks
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
After you change model type (Geometry > Structure type) to the 3D Frame you will be able to define loads acting in the global Y direction which is perpendicular to the bridge.
Artur Kosakowski
