I'm modeling a long building (36x140 m2) and when I run the modal analysis it takes quite a long time calculating. It also says that mass participation is not satisfactory. When I try to see the modes of vibration it gets even slower and I dont get to see them.
Structure has 8 slabs, bottom 2 slabs are simply supported to portray the underground walls. Beam is just on contour of slabs, and slab is simply supported on internal columns. I used emmiters above columns for a better meshing option (High number of nodes).
RT file is quite large aprox. 80MB.
Not sure if its normal to take so long due to being a large building, or I am doing something wrong.
Thanks in advance!
File to large for attachment.
