Slenderness ratio calculations uses wrong radius of gyration
Hi All,
I'm facing a problem in the design verification of structural steel columns in Robot 2019 and was wondering if someone had a solution?
My design follows AISC, and when performing the slenderness check, Robot switches between the correct radii of gyration values (ry and rz). For instance looking at the first image, the circled column is a UC 356x406x467. The radii of gyration should be: ry = 10.7cm and rz = 17.5 cm as per the orientation of the column, however they are reversed in the calculations (image 2) and hence I keep getting an instability error.
Was wondering if someone faced a similar issue before and if they found a fix for it?
I noticed the same issue in the forum question below:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/slenderness-value-in-steel-design/m-p...
But the solution is for robot 2013 and i'm currently using Robot 2019.
Thank you.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
In Robot Structural Analysis
Iy, Ly,ry ...parameters refer to plane parallel to I section web
Iz, Lz,rz...parameters refer to plane parallel to I section flange plane
Looking at your structure screenshot, I think that buckling length coefficients are defined not correctly for selected column ( Ky should be >than Kz )
I have checked manually slenderness and radius of gyration values and they seem to be correctly calculated
Krzysztof Wasik
hasan.icat
Community Visitor
Community Visitor
Hello, friend gave an answer, but I found a site online that you can verify. You can verify your calculation here. (link to calculation)
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
