Message 1 of 18
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear Colleagues
Could I get responses for the following Inquiries :
- Why does the max. slab deflection value in the capture (01) is greater than in the capture (02) for the same slab parameters?
- Which deflection value shall I consider as " Long term deflection "?
- Is there any possibility to get the elastic slab deflection directly from ROBOT ?
Note : If you use any capture for explanation . Kindly , send it as attached .
Thanks in advance.
Refaat
