Slab Spanning Direction Issue
eoin.duggan
eoin.duggan
I'm having an issue with defining the slab span direction in my building model.
I have composite floors and metal deck roofs that I wish to span in the X-direction. However, they currently span in the Y-direction, despite having specified that the panels are to span in the X direction.
On the attached model you can see that under gk_upper roof that not distributing any load to the beams running the Y-axis. I would appreciate your help in rectifying this.
Eoin
ByrnePM
Eoin,
You need to change the local panel orientation to match the global X asix orientation,
To do this, I had to change your structure type to shell design - then select your roof panel and go to geometry - properties local panel direction and change to global X vector
(see load distribution of roof panel below)
Mohammed_Ata
