Slab reinforcement problem
has anyone encountered similar problem, as i run provided reinforcement verfication, i get this message:
"Zones do not cover all the regions where reinforcement ir required"
I get this message with manual reinforcement placement also. Its so frustrating 🙂
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm not sure if I understand this issue correctly. Looking at the picture my assumption is that there are no zones defined. Could you attach the file with the zones you defined manually?
Artur Kosakowski
Sorry, i forgot to run reinforcement calculation, before verification. Now everything is fine. Thanks for response.
