slab design strips
slab design strips
Message 1 of 8
slab design strips
Hi my friends
slabs are designed by  three methods according ACI code , one of them is strip method which it uses also for mat foundations  , and its available in "Safe "
program , is it have in robot ? or robot how design slabs , which method ?
any guide makes me happy .
Replies (7)
Message 2 of 8
Muhammed.OPERA
Hi @Anonymous
I'n not familiar with SAFE but if you mean taking cuts through panels, see that:Panel cuts.png
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Message 3 of 8
thank you dear @Muhammed.OPERA
No , my question is about ( design strip method ) ,, its a method for hand calculation  designing in slabs , its also use in etabs and safe ,
but maybe have not available in robot , may it use finite element method ,
Message 4 of 8
Message 5 of 8
Mohammed_Ata
There is no such technique in Robot like SAFE. Strips are only for exploring results through s determined section in the slab.
Message 6 of 8
which is better dear @Mohammed_Ata
Message 7 of 8
shefypattambi
Hi @Anonymous,
The strip method in SAFE is same as the wood and armer method using by Robot to design the slab and it is recomended to use wood and armer method for the design of slab and finite element method for design of Wall Element.
Message 8 of 8
17520800280
Observer
Observer
is there any other way?
Because the panel cut is calculation 1m, but ACI design strip with width on each side of a column equal 0.25l
