Slab deflexion
Slab deflexion
Message 1 of 13
Slab deflexion
I have a slab supported by beams.
In the beam 7 the maximum deflection is 21 mm (attachment) in the same point the maximum delfexion of the slab is 75 mm (attachment)
How is it possible if the slab is supported by the beam?
How I fix the problem ?
thank you
Replies (12)
Message 2 of 13
This job it's now urgent, any answer to fix this problem will be apreciated.
Message 3 of 13
Is it possible to have any answer please?
Message 4 of 13
AhmedZA
panel cuts results  28.7
diagram for bar     28.7
for case =  4
Message 5 of 13
AhmedZA
Message 6 of 13
Thanks Ahmed, but I ask for the slab deflexion in required reinforcement module (75 mm) it’s biggest than support steel beam, please see the attachments in my first post.
I think this is not possible have more deflexion in the same point in slab than the support beam
Message 7 of 13
AhmedZA
such case you need to increase moment of inertia of beam ( more rigidity - more bending as well as more deflection)
Message 8 of 13
AhmedZA
oops sorry    i mean concrete beam u are using steel beam so
may be this helps
Message 9 of 13
AhmedZA
and decide  (coefficient   )
Message 10 of 13
No, is not possible element (slab) go under his support (beam)
Support technique what is wrong in my model?
Message 11 of 13
In attachment you can find a more developed model, now I have only one slab, the supports beams are 100 mm under, the slab and supports beams are connected every mesh joint by rigid links and de result is the same.
“in de module concrete required reinforcement, the deflexion of the slab in service load state is more than the support beam”
What is wron in my model?
thanks
Message 12 of 13
We waiting for an answer of support team, my apologies for the pressure but this job it’s urgent.
Message 13 of 13
Rafal.Gaweda
Autodesk Support
Autodesk Support
On stage of RC design the slab \ panel is separated from model so these results are different \ not comparable
To get similar \ more accurate RC results first you have to run required reinf calculations for slab then run Verification With Stiffeness Update.
Rafal Gaweda
