Simply supported distribution slab at ground floor supported on linear supports
skellyRSA2023
skellyRSA2023
Hi, is there a way of modelling a simply supported slab as a load distribution element only at ground floor level supported on a linear line support? I.e. not an FE meshed out slab just a load distribution element so as i can obtain the linear line loads from the slab at the ground supports? Its seems to work when you use a load takedown one-way slab (without stiffening) onto a beam however not onto a linear support? Has anyone worked out a way to do this. As i am just looking to obtain the lines loads on the foundation plinth from suspended ground slabs. Any comments or advice would be appreciated.
S.
Rafacascudo
If it is a cladding or a non meshed panel ,Robot will use the simplified method for distributing the loads and then , you have always discharge this load on structural objects like bars , or meshed walls or slabs. The best You can do is use fake beams on the slab edges
Rafael Medeiros
skellyRSA2023
Thanks Rafael. Yes I have generally come to this conclusion, or just mesh the slab out as a one way distributed slab etc. thanks for your help.
