Message 1 of 8
Greetings, please advice on the following case
i have a retaining wall that carry a column starting from ground floor , the column is shifted 5 cm from the centre of the wall and i want to make this in my model.
so is this is the best way to model it ? or should i make the column start from the bottom of the retaining wall? is a one rigid link between 2 nodes is enough to mimic the real case or more rigid links are needed ?
Also regarding the design is it possible to design this retaining wall in robot
your suggestions are highly appreciated
moustafa elgaar
