Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
shell problem - opening in cylinder
9 REPLIES 9
Message 1 of 10
1313 Views, 9 Replies
Hi All,
 I am facing problems in object combinations . I have to insert 2 circular openings and a rectangular opening in the circular wall. I have inserted one circular opening but the remaining openings are not being inserted. The issue its is saying "that the object 2 cannot participate in the object combination". Object 2 is the circular wall into which the opening has to be inserted. I am using double operand Boolean operation - mixed command for object combinations.
9 REPLIES 9
Message 2 of 10
Rafal.Gaweda
Hi @Anonymous
Basing on this forum thread , you have to create big cylinder as 3 parts
File attached.
Rafal Gaweda
Message 3 of 10
in reply to: Rafal.Gaweda
Hi Rafal,
Thanks for your response. I have a doubt i.e. cant we insert the openings without breaking the objects as this would increase the time to apply the loads and stiffness to the walls. I have a reference in which 2 openings are inserted in a circular wall. I am attaching the same for your reference. If we can insert 2-3 openings without breaking the walls, it would be of great help to me.
Thanks in advance !!
Message 4 of 10
Rafal.Gaweda
Hi @Anonymous
Yes, you can do it in one run:
Rafal Gaweda
Message 5 of 10
Thanks Rafal, it was too much simple.
Message 6 of 10
Simau
Hi @Rafal.Gaweda @rafacascudo
I try to follow this video, but i can't get same tools in Object Combinations window
My window:
M2.jpgM1.jpgin the video
in the video:
M. Agayr
Message 7 of 10
Rafal.Gaweda
in reply to: Simau
Hi @Simau
See this post.
Rafal Gaweda
Message 8 of 10
Rafacascudo
Ok Rafal . But where is the "advanced" button on that window. I remembered having it in the past but couldn´t find it on 2018 or even on 2017 , 2016 versions.
Rafael Medeiros
Message 9 of 10
Rafal.Gaweda
in reply to: Rafacascudo
Hi @Rafacascudo @Simau
Rafal Gaweda
Message 10 of 10
@Rafal.Gaweda how do you extrude a circle?
