Message 1 of 10
HI,
Has anyone ever tried to analyse a sheet pile wall with Robot?
Have a good day,
Mathias.
HI,
Have a good day,
Mathias.
Hello, @mathias_peron
you can see these link it may be helpful 🙂
https://www.youtube.com/watch?v=cNzy1SJTsGg
https://www.youtube.com/watch?v=fMqcW3Zj7GU
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Hi mmlovemtk,
Thank you for your answer but I'm looking to model something like this (see attached).
Has anyone ever done something similar with Robot?
is it possible to show what you want to model?
I have some expirance with sheet piles use ase bearing piles.
Please see attached.
nothing attached?
Sorry.
Use frame 2d structure type.
Sheet pile as a regular bar with a section of 1m width , so you get the results /meter
use bar elastic ground from Geometry/additional atributes.
2 types of ground
1-where there is soil on both sides , divide the pile bar and set the spring value and assign to the corresponding bar lenght
2- upper part with soil on one side only , the same , but use the uplift on the correct direction on the unidirectional tab.
Apply the soil loads on each side .
Also apply a vertical support on the pile base to avoid instability warnings
Rafael Medeiros
Thank you, that might do 🙂
Hello , @mathias_peron
I would suggest to use this software it will give you best result
and as @Rafacascudo mention that you could do it in robot
but i still preferred to do it with a software that is interested in this field
you can add a construction stage with it and it very easy to use
the soft name is Deep Excavation Software
https://www.deepexcavation.com/en/deepxcav-2011
(see attached)
