Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Shear Stress Tz null, why?
4 REPLIES 4
jo2ny
621 Views, 4 Replies
I'm checking a lifting beam 4m long - a HEB 320 profile.
The main resulting inner force is the shear - FZ.
I ran the model, and now i'm checking the results in the Detailed Analysis.
It shows, the sear Fz = 930kN, but no Shear stress Tz. My question is why?
If i go to the stress analysis section and check the TauXZ, the value is corect.
Does Tz represent something else?
Tags (2)
4 REPLIES 4
Artur.Kosakowski
in reply to: jo2ny
That indicates that some section's properties are defined as 0. Which section database is this section from? Could you attach the rtd file?
Artur Kosakowski
jo2ny
in reply to: Artur.Kosakowski
yes, here it is;
the HEB320 section used is from the DIN database
jo2ny
in reply to: jo2ny
the HEB320 section used is from DIN database (DINpro)
i attached the rtd
yes, i changed the section. I used same HEB320 but from the EuroProfile databse, and Tz is no longer null.
i guess, the one from DIN is missing the shear area value ?
Artur.Kosakowski
in reply to: jo2ny
Indeed in this database values of Wy and Wz for HEB sections are 0s. Please use the Euro section database instead.
Artur Kosakowski
