Set Material through API
Message 1 of 10
Hello!
I have seen this post https://forums.autodesk.com/t5/robot-structural-analysis-forum/vba-excel-macro-for-any-object-geomet... very very useful, thanks to @Rafal.Gaweda.
I would like to have inside that API a tool in order to get the "Material Definition" information inside the excel, then changing or adding a new material still inside excel, then update everything into RSA.
Thank you in advance
Replies (9)
Message 2 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I am attaching two example which should allow you to start writing your own macro.
Rafal Gaweda
Message 3 of 10
thanks @Rafal.Gaweda for answering,
but I get the following error when I try to change material's name
Message 4 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
As you may see from your screen shot, this macro can Get material and Update it (= update its  properties) , not for creating new one (new one = new name).
Rafal Gaweda
Message 5 of 10
How can I create new one material?
Message 6 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Example code:
Private Sub CommandButton1_Click()
Dim RobApp As New RobotApplication
Dim MatLabel As RobotLabel
Dim MatData As RobotMaterialData
    Set MatLabel = RobApp.Project.Structure.Labels.Create(I_LT_MATERIAL, "MyMaterial")
    Set MatData = MatLabel.Data
    MatData.E = 200000000
    MatData.Kirchoff = 3000000
    MatData.RO = 400000
    MatData.NU = 5000000
    RobApp.Project.Structure.Labels.Store MatLabel
End Sub
Rafal Gaweda
Message 7 of 10
thanks @Rafal.Gaweda for answering again,
but I'm still not able to import the material edited (both name and properties) from Excel to RSA through API
Message 8 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Screen shot below
Rafal Gaweda
Message 9 of 10
Yes you are right, but is it possible to have it in the "concrete" window instead having it in "all" .
Instead putting "my material" inside the macro, could be nice to import the name of the material from the cell!
The macro imports directly the values into RSA, but it doesn't import from the cell's value like here https://forums.autodesk.com/t5/robot-structural-analysis-forum/vba-excel-macro-for-any-object-geomet....
To summarize the issue, Is it possible to import name and properties from excel cell value into RSA?
Message 10 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dear @Anonymous
Add
MatData.Type = I_MT_CONCRETE
Could you do a small effort from your side and try yourself?
I showed you all pieces. Just use them in the way you want.
Rafal Gaweda
