Separate structure error with geometric imperfections
Message 1 of 10
Hello
I got "Separate structure error" when tried to analyse model with geometric imperfections
If imperfections deleted from model analysis going fine without any instabilities or errors. Imperfections defined by default type "Automatic" to columns, bracings and stringers. After canceling analysis all nodes in model become separate.
Replies (9)
Message 2 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
Message 3 of 10
Here is the file
Message 4 of 10
Interesting buckling mode
Message 5 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
I got warning about separate structure but nodal list is empty so I guess warning is irrelevant
Buckling mode - I suspect you are running buckling on model with imperfections. If so it can be hard to check buckling modes because members can go out of different planes
Rafal Gaweda
Message 6 of 10
I tried to ignore this warnng, but got huge (billions of mm) displacements of columns when checking columns in steel design tab.
Also I tried to add local imperfections
- in one direction
- only to central columns
- by forces
It's not helped too.
I am running buckling analysis only to check value of critical force for model.
Message 7 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
Let's put it this way: model you sent had no imperfections and no buckling so I defined them by myself.
If you want us to check what you really got you have to send us up-to-date model with all settings you made.
Otherwise we will be still "walking as a blind man"
Rafal Gaweda
Message 8 of 10
Here is the last version of file. It is without buckling analysis because of separate structure warning and some unreal reslts (look screenshots). Only local imperfections.
Message 9 of 10
Rafal.Gaweda
Autodesk Support
Autodesk Support
I am afraid you have to delete imperfections from bars to get correct results.
Rafal Gaweda
Message 10 of 10
😞 too bad... Anyhow, thank you for tried to help, Rafal. Best regards
