Selfweight
Selfweight
rakim6AFX6
Selfweight
rakim6AFX6
uni freshman here, hello guys. Im hopping im on the right forum for the silly question im bout to ask in regarding to my confusion about selfweight formulas.
i been told that self weight is = mass*gravity, ok so far.
The more i watch videos and read i seem to get confused in other ways to calculating selfweight. for example, if have density and not mass.
i see people dong this
density * volume = weight.
i scratch my head and thinking, isnt that a mass? im looking for selfweight of structure member in kN. For me, to get it in kN, must i multiply by gravity?
i see a lot video on youtube calculating selfweight of a slab like this
2500kg/m^3 * Volume of slab.
if selfweight is mass * Gravity, why the above example isnt multiplied by the gravity then if density * volume = mass, shouldnt the mass then multiplied by gravity?
Another thing that confuses the life out of me is the unit weight business. the 2500kg/m^3 is the unit of density, but i hear 'unit weight' in videos. And, when i do example question sometime im given unit weight in kN/m^2.
so what is it?
my understand is that if im given unitweight in kN, no need to multiply with gravity, except i have to watch out if is in kN/m^2 ill need to multiply by length. is this thinking correct?
Clarification will be helpful, especially with just finding selfweight with only density and volume. Any  good source of material where i can read more will be helpful too. Thank you,
Uni Freshman.
Stephane.kapetanovic
Hi @rakim6AFX6
it is likely that in the videos there are confusions. likewise in the units of the formulas. As 1kg by simplification is "equal" to 1 daN then all the simplifications are "valid".
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
saclovitzky
Just stick your thought on this,"i been told that self weight is = mass*gravity, ok so far."
SW can be expressed in kN/m or kN etc.
Density of materials are  normally expressed in kg/m3 or kN/m3,if you are using SI units,just stick to kN/m/m2 units
and you will be fine(ie, if the density is in kg/m3, just convert kg to kN and your fine).
Hoe this helps.
