Seismic force plot and results verification
antonio.lafuente
Message 1 of 11
antonio.lafuente
Good morning
I am a bit suspicious of my seismic analysis results and was wondering whether I may have missed something. To start with for some reason I can't manage to plot the seismic loads the code is generating even after running the analysis and having checked the right option under preferences.
Second, if I look at the reactions from the seismic load cases the values look pretty low for the close to 100 Ton of converted mass taken into account in the modal analysis and the response spectrum I'm using.
Am I missing something? There seems to be something off with these results. I'm attaching anyway the file in case someone can have a quick look and give me a hand. Thanks a lot in advance
Replies (10)
Message 2 of 11
Romanich
Hi @antonio.lafuente ,
What I can see on Robot 2022, that you have execution error 2550  related to the eigenvalue problem (internal error while reading from a scratch file during eigenproblem analysis)
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 11
antonio.lafuente
Strange. I don't have such error with Autodesk Robot 2020
Message 4 of 11
Simau
Hi@antonio.lafuente
Change the order of the load cases in order to have the seismic cases directly after the modal case.
M. Agayr
Message 5 of 11
antonio.lafuente
Hi!
That seems to have helped :). Thanks! I still can plot the forces though. Any idea on how to do this?
Message 6 of 11
Romanich
Roman Zhelezniak
Message 7 of 11
antonio.lafuente
Thanks! Is this the only way? Can you not plot it in the load definition section? I though I had done this in the past or seen it done elsewhere
Message 8 of 11
Romanich
In addition it is possible plot as added masses converted from the load:
Or check results in the table:
Roman Zhelezniak
Message 9 of 11
antonio.lafuente
Thanks! Bu t shouldn't I be able to see these forces when activating forces generated automatically?
Message 10 of 11
antonio.lafuente
Hi again Simau
I'm going through the results and maybe I'm missing a concept from the theory side, but shouldn't the spectrum applied on the X direction result in reactions only in the X direction? It is for the same model I attached in the beginning
Cheers
Antonio
Message 11 of 11
Simau
@antonio.lafuente
nothing abnormal since your structure is not perfectly symmetrical in load and rigidity
M. Agayr
