Seismic Equivalent Lateral Force / Non-linear uplift released elastic ground
EduardoMeruvia
EduardoMeruvia
Hi all,
I'm having an issue running a Seismic Equivalent Lateral Forces analysis of a Steel Frame structure on top of a slab on ground foundation.
The issue I have is that my slab is currently defined as a uplift free panel (i.e. the slab is free to move upwards under uplifting forces) and thus a non-linear analysis is required as soon as this non-linear behaviour is set up in the model. Model Set up - Slab FoundationModel Set up - Slab Foundation
 After setting up my Equivalent Lateral Force Method analysis parameters and load combination I run the model and as expected the Equivalent Lateral Force cases will not converge under non-linear condition as this is an unstable load condition by itself. Normally do to get around this "issue", I set up the Equivalent Lateral Force load cases as Auxiliary primary cases but then include them fully in my load combination hoping they would come through/compile in that stage and ultimately converge as a nonlinear load combination.
However, while going through the process above I realised that although convergence was achieved on all load combination NONE of the automatically generated Equivalent Lateral Forces were created i.e. the Equivalent Force cases were "empty". I tried a few variations of the procedure mentioned above but none with positive results. I just seem unable to generate the Equivalent Lateral Forces whilst having a uplift free slab foundation.
I have look in the forum for possible previous answers but unfortunately couldn't find much that could aid my case.
Found the post below somewhat related, and also tried using 'Definition of a Starting Case for Non-linear Analysis" to see I could address  my issue but again I seemed unable to.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/no-convergence-with-uplift/m-p/343727...Starting Case Def.Starting Case Def.
Just to make sure that its nothing wrong with the model, I run an analysis with the slab foundation having NONE uplift released direction (i.e. linear analysis) and the Equivalent Lateral Forces work perfectly as expected.
 Getting nowwhever at the moment, so if you know of a solution or method that can help me I would appreciate your help!
 Thanks in advance!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EduardoMeruvia
If you allowed for the uplift then you have some vertical loads that counteract the overturning moment due to the horizontal loads. In other words you shouldn't run the ELF case alone but at with all acting dead loads together.
See this article and let me know if it needs any improvement so that it answers the similar questions in the future.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
EduardoMeruvia
Hi
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EduardoMeruvia
For the load cases which are needed for actual load generation (as ELF) just allow them to diverge (and do not check their results as if they were set as auxiliary) rather than set them as auxiliary.
Artur Kosakowski
EduardoMeruvia
Thanks for the response!
I ended up going with Modal - Seismic which is just as easy but was still wondering about a solution to the question above. Just tried it and seems to work that way!
mgaafar
Hi Artur,
               I did what you said but what happened that the analysis stopped after it did not converge and did not analyze the other load combinations with seismic. and when I made the seismic cases (Equivalent lateral) as an Auxilary case it does not generate the automatic load generation.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
