Section Properties update in the print out composition
I am trying to have a standard print out composition to use as the default one in my projects.
The problem is that the "section properties" part is not updating, it always shows the first project sections !!
Please take into consideration that if I got the section properties from the simplified print out, they will be updated !!
Please find attached screen shots for clarification.
Please note the following:
The sections that I am using for this project are 30x4mm rectangular section, and 22x4mm......but in print out it is still giving 60x6mm & 52x6mm.
Thanks in advance for help.
Rafal.Gaweda
Autodesk Support
Autodesk Support
You are right.
It must be corrected in software.
Workaround : generate Section Properties again after sections change on model.
Rafal Gaweda
Thanks for clarification.
