section design
section design
section design
Dear sirs
I have to model a composite section ( reinforced concrete+plastic) as the one in the attached picture. Could u pls give me some indication about how to use the module Sectio design (if applicable) to do that or have I to do in some other way?
Looking forrward yr kind anwer I thank u in advance
brother55
Artur.Kosakowski
Autodesk Support
Autodesk Support
The way of creating multi-material section was described in the 8th RSA webinar. Check slides 27 to 29.
http://forums.autodesk.com/t5/robot-structural-analysis/robot-structural-analysis-webinars/td-p/5523...
Artur Kosakowski
