Second order effect and frame imperfections
KillianPMG
KillianPMG
Hi guys,
I've attached an snip from an SCI design guide below.  I'm designing a tall steel braced building. Bracing is in the form of K-frame therfor tension and compression.
I'm trying to understand how to conduct full second order analysis and any limitation with using second order analysis in Robot.
If I select non linear and p delta effect in analysis parameters, is it correct to assume robot accounts for:
  • frame imperfection, so I do not have to apply notional horizontal loads (EHF) as per eurocode
  • second order effect due,to the deformed geometry, is accounted for in the analysis.
Are there other settings or important points I should look out for when running a second order analysis in Robot 2015.
My building is 40m high, each column has nodes at approximately 6m centres ( from research I believe it important to have internal nodes to run non linear, p delta analysis).
Thanks for your guidance.
Killian
Rafal.Gaweda
Autodesk Support
Autodesk Support
I think p delta effect in analysis parameters is correct to be assumed.
Rafal Gaweda
KillianPMG
Rafal,
Thanks for your reply.
So I can just select p-delata analysis box and leave the non lnear box unticked.
Regards
Killian
Rafal.Gaweda
Autodesk Support
Autodesk Support
pdelta+nonlin will be ticked
Rafal Gaweda
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
t.sautierr
"frame imperfection, so I do not have to apply notional horizontal loads (EHF) as per eurocode "
Maybe I missed something in RSA, but i think it is not performed automatically -> you have to set this effect manually even when pdelta is ticked.
t.sautierr
"1- Consider (P-Δ and P-δ) Effects ( flexural, shear and axial deformations).
2-Consider the initial Imperfection whether by direct modeling of that Imperfections pf structural members or by inclusion of notional loads.
3-Reduction on the member stiffness to remove the partial yielding due to residual stresses in the members which is creating destabilizing effects."
What difference you make between P- small delta and 3)? To me 3) is related to push-over analysis and is not taken into account even when p-small delta is ticked?
