Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
SDOF oscillator model in Robot
3 REPLIES 3
howard.irons
435 Views, 3 Replies
Hello
I would like to do some modal and response spectrum validation work with Robot (to understand the seismic input parameters), and so would like to build a simple SDOF oscillator model, ie mass on a stick
Does anyone know how I can
a) build a bar element with defined stiffness, but zero mass.
b) assign a mass to the end of the bar
I can then run a modal analysis and input spectra into the model to obtain a known result to validate the program to understand the inputs and parameters before going on to bigger models.
3 REPLIES 3
Rafacascudo
in reply to: howard.irons
for a) , create a material with Zero specific weight and assign it to your bar . On Tolls/ Job preferences
For b)  , create a load case and apply nodal mass to the top node
Rafael Medeiros
okapawal
In order to neglect self-weight mass in dynamic analysis you may also check "Disregard density" option in Modal Analysis definition.
Waldemar Okapa
Sr Product Owner
howard.irons
in reply to: Rafacascudo
Classification:UNCLASSIFIED
Thankyou Rafascudo, I have successfully performed the analysis following your advice.
