Hi @BertelliMarco1095
I understand that you'd like to see more features in the newer version of Robot. I would as well but what you wrote about Robot users being treated unfairly is not true.
For the technical part: the more object oriented the program is the more difficult it is to keep the backward file compatibility. In Robot V6 which used to save the file in a text file it was easier but still if you'd add the syntax for a new functionality in its new version it would not be correctly read in the old one with the text 'reader' not knowing it yet. The same applies to RSA - if the database format changes to accommodate new features or when it is imposed by new IT tools used e.g. to compile the program internal code then an rtd file format becomes incompatible with the older versions of the program. To have it compatible would mean to 'rebuild' old version with new features or have them lost without being read (part of data missing with no warning) or recompile it (old version of Robot) so that there is no crash while reading 'new' file binary format which just means updating it to a new version (if that would be even possible).
For the unfair treatment due to the number of users; see the same being applicable to e.g. Revit:
Backwards compatibility of Revit with earlier releases of the software
I hope it explains the situation a bit for you. Please keep the future thread titles aligned with the Community ground rules. Thank you.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
